Vibrations
Replaced all 3 u-joints and the center support bearing in my 96 extended cab 1/2 ton 2wd. All 3 u-joints went in with no problems as did the support bearing. There was no vibration before I changed out the parts and now I have a noticeable vibration 45 to 65 mph. What did I do wrong? I am clueless at this time. I have done this job on other trucks with no problems so I'm sure I got it right...Help!
Regards, Junk |
Wow 226 views and not one suggestion...
I'd guess you "clocked" or "phased" the shaft wrong, did you mark how it lined up before you disassembled?
I checked the carrier bearing and it seems to be in position and lined up with the drive line. I have access to a lift tomorrow and I will turn the drive shaft 180 degrees. I marked the shaft but the guy that was assisting me put the shaft up in the rear and he missed the marks I left on the rear yokes. ...Live and learn...Dumb mistake on my part.
Thanks for your reply |
happens to everyone, hopefully that's the whole issue
Turns out the center support bearing was defective...it will be replaced with another one and I hope this one is good...
