what trannys fit a 2000 silverado 1500?
hello all, I have a 2000 silverado 1500 4x4. the tranny goes in reverse but not forward at all. I am thinking of buying a used transmission for it but am not sure what years and models will be a direct fit. I am looking at a 1999 c2500 single cab transmission. will that be a direct fit? am not sure. any help would be great. thanks epi
4L60E swap from a 1999 Tahoe to a 2000 silverado
I have a 2000 Silverado 1500 4x4 and the transmission lost 3,4,and overdrive,I bought a rebuilt that I was told was an HD rebuild,after installing it I found out it only had first gear,I swapped the servo and then I had first and second,but the fluid went from bright red dex.6 to burnt dark fluid,the guy promised me a new transmission but I never seen him again so I bought a 1999 Tahoe 4x4 for the transmission,now my Silverado has a vortec engine and the Tahoe doesn't,both transmissions are 4L60E's but before I go through the trouble of pulling the tranny out of the Tahoe I sure would like to know if they can be interested,if any body know for sure could you let me know,thanks
I have a 2000 Silverado 1500 4x4 and the transmission lost 3,4,and overdrive,I bought a rebuilt that I was told was an HD rebuild,after installing it I found out it only had first gear,I swapped the servo and then I had first and second,but the fluid went from bright red dex.6 to burnt dark fluid,the guy promised me a new transmission but I never seen him again so I bought a 1999 Tahoe 4x4 for the transmission,now my Silverado has a vortec engine and the Tahoe doesn't,both transmissions are 4L60E's but before I go through the trouble of pulling the tranny out of the Tahoe I sure would like to know if they can be interchanged
I just recently did the same thing.. i am having trouble with it shifting ,,i think the pins maybe different i am trying to find out if anyone out there may know i sure could use the info.. you will have to switch bell housing out other than that and trying to figure out if this is the problem
ix3oh3xi
Silverado & Fullsize Pick-ups
August 30th, 2010 11:12 PM
00, 1500, 2000, 4l60e, 4x4, chevy, compatible, fit, forums, silverado, tranny, trannys, transmission, transmisson, years
