02 Silverado pwr lock question
I am new to this forum and I just bought a 2002 silverado1500 regular cab. with 105000 miles and it is in fantastic shape. All fluids changed, plugs were in immaculate shape, no oil residue. Has manual windows/seats and i was told by the owner manual locks. 4x4 on the floor and factory SNOW PLOW PROVISIONS(VYU).
I just took apart the driver door panel to lube the tracks and there are electrical connections to the lock. Also there is an aftermarket engine start installed. When i hit the lock/unlock on the remote a relay under the dash clicks and the bell rings. Exterior lights flash as well. Inside the locks are a manual slide. I pulled off the fuse panel and from what i can see the
are not there.
Anyone know if i buy these relays and install if the power locks will work?
Do i need all these relays?
Thanks
DRV UNLOCK Power Door Lock Relay
L DOOR Power Door Lock Relay
UNLOCK Power Door Lock RelayL DOOR Power Door Lock Relay
are not there.
Thanks
Bogeymanmcs
September 1st, 2010 9:27 AM
linkovich
August 21st, 2010 7:12 PM
7.4chvy
July 25th, 2008 9:47 AM
