1988 C1500 Crank/No Start
Crank/No Start 1988 C1500 262L V6 with manual transmission.
New parts added:
Spark plugs, spark plug wires, whole distributor,
Ignition Coil, Fuel Filter, Fuel Pump Relay, Fuel Pump Fuse, Throttle Body Sensor, Clutch Pedal Ignition switch, cylinder ignition key lock, Timed to TDC,
Any suggestions??
New parts added:
Any suggestions??
check the fuel pressure
Kevinkpk,
Original problem was crank / no start. first part replaced was the ignition coil. it ran for about a week then did the same thing. It had the original coil put on from factory with the riveted bracket attached. Nothing has been changed on this truck at all. It was an old shop truck that probably had the oil changed, tires replaced, fueled up.
It is getting fuel
Thanks for the help
It is getting fuel
Thanks for the help
RChilds69
September 18th, 2015 10:36 PM
