1995 Chevy Silverado 1500, 305 V8 Stalling
Engine Performance problem
1995 Chevy V8 Two Wheel Drive Automatic 175000 miles '95 Chevy 305 V8 Truck idles in Park & Neutral just fine. The truck cuts out and stalls after stopping. Several things have been replaced. Throttle Position Sensor PCV Valve Distributor & Rotor Fuel Filter Spark Plugs We have checked everything simple so far. We are leaning toward the fuel pump but we want to check the pressure & pressure regulator. There is no way to check the pressure. There is one fuel line and a return line. Can someone explain how you check the fuel pressure? Surely there is some trick that the dealership or a technician does to check the fuel pressure? I'm leaning towards cutting the rubber part of the fuel line and installing a "T" and connecting a fuel pressure hose/gauge to check and see whats going one before buying and changing the fuel pump. Any tips? Nate |
there is an adapter that goes in place of the fuel filter or look back at an older thread about tbi
| All times are GMT -5. The time now is 4:05 AM. |
