2002 hd2500 4x4 4door ac cold- not cold
the a/c will be cold then not cold
what can i check on this truck to get it going ? has freon has good clutch and compressor has new accumulator has new accumulator switch |
Is the compressor cycling to quick ? If not and it has proper amount of freon, it should cool. To much freon as well will not cool as it should. Good luck,
david :) |
Cycling too Quick
When you say cycling too quick ---
How quick is too quick ? What is the acceptable time for the cycle on off of compressor ? MARK |
check how much refrigerant you have to start with
freon is in the green
freon is in the green - had approx 1.75 cans of freon
i checked the schrader valve on low side and it is good the switch on the low side is working |
what does "in the green" mean and how big are the cans? if it gets cold interittently the first things to check are refrigerant charge, clutch air gap and pressures
installed amount
used a vac pump on the system to put negative pressure in the system
put in 2 two oz. ounces of compressor oil put in 1.6 lb of freon the guage I had was yellow low pressure green correct pressure red too much pressure |
2002 HD2500 A/C not cooling
took out orifice tube cleaned it
replaced it recharged with 2 cans of refrigerant :mad: still not cool 80 degrees out vents pressure is 25 Lbs to 70 lbs during cycle of the compressor clutch is working any ideas :confused: |
NEVER FREAKING MIND
This is now fixed Clogged orifice tube I figured it out and fixed it thanks for no replys folks This group was pretty much useless in my case |
well you have to have patience people don't just hover over the forums all day and people that do it all day at the shop dont always feel like being nice and giving away free knowledge that most people pay for.
Did your "cans of freon" have sealer in them? most of those crappy "top off" kits do and if they did YOU probably clogged the orifice tube, and if you didn't then you'll have bigger problems in the future or someone did a repair half ass in the past. A/C is a sealed system you shouldn't randomly develop a clog. |
| All times are GMT -5. The time now is 11:22 PM. |
