2004 6.0l problems, falls on its face or wont go
#12
thanks for all the input guys! so here is the run down as it stands. thursday i replaced the MAF and (fingers crossed) every thing seems good! no codes or stumbles! The mileage is just a few hundred over 100000, i intend to change those plugs SOON, the air filter looked brand new but im interested in a CAI, can someone suggest a good product. therewolf the truck is an automatic so im not sure if i have the shift indicator light????? the engine light was on but had it cleared after i replaced the MAF an so far so good! thanks for the suggestions about the sea foam, ill be smokin up the neighborhood soon!
#13
when you change your plugs change to iridiums. some people like the cai and some dont. i posted a thread about cai probably on like 2nd or 3rd page maybe 4th. check it out.
#14
s34n is right about those iridiums.
No, I think you misunderstand me, stotts.
If you look at your speedometer, right below the gauge you should see your auto trans shift indicator--(PRND321). It doesn't light up when you need to shift, it merely underlines the gear you choose to shift your transmission into. I explained this poorly to begin with.
Right below that is a DIC which usually shows your Odometer mileage. In the event of a problem for which the '04 has a sensor, many times a prompt or code will flash instead of your mileage at startup. This could save you a bit of trouble.
Chevrolet Forum News
February 12th, 2015 4:28 PM
Zackman1995
12
February 3rd, 2012 8:34 PM
