-   Silverado, Sierra & Fullsize Pick-ups (https://chevroletforum.com/forum/silverado-sierra-fullsize-pick-ups-21/)
-   -   2008 Silverado Brake Issue (https://chevroletforum.com/forum/silverado-sierra-fullsize-pick-ups-21/2008-silverado-brake-issue-49236/)
David_ICC Mar 8, 2012 5:58 AM
Short Summary:
2008 Silverado, Replaced Front Rotors and Pads (115,000 miles), Brake pedal will not build pressure, Pedal basicly goes to the floor, Right front has no air when bleeding, left front has air will not bleed. when truck is running the pedal goes to the floor and very slowly returns to the top.
EinST Mar 8, 2012 11:54 AM
Welcome to the forum.:) Forgot to cap the brake hose? Consider taking it in for service. You won't be able to bleed it properly without a scan tool that can work the ABS.
nkh34 Mar 9, 2012 5:34 PM
Hey EinST just out of curiosity is that something you can do with the mighty vacs or the one person bleeder? i had this same thing happen and i mighty vaced it and it seemed to be fine, but now you have me wondering if i should have it redone with the scan tool? biggest fear is loosing braking ability
EinST Mar 9, 2012 8:51 PM
The scan tool is for working the valves in the BPMV when the brake pedal stays soft despite manual bleeding. If your pedal is firm, it isn't necessary unless you're going for a complete fluid change.
nkh34 Mar 11, 2012 10:17 AM
Ok thanks thank you I was wondering what the scanner did but now that makes sense
