2019 Silverado - Where is the GCWR?
Hi there. I'm looking to buy a 2019 Silverado 1500 LT w/2LT and have the VIN. We are going to be hauling a two-horse bumper pull with a GVWR of 7,000 lbs. I am aware of all the other specs for towing, like tongue weight, rear axle ratios and weights, etc. What I'm looking for, however, is the GCWR, and most dealers I talk with can't seem to find that number. Some folks say that it should be on the door placard, but it's NOT on the 2018/19 models. Is it in the Owner's Manual?
The tech specs found through the VIN search on this forum doesn't offer a range, as most VIN results have. Instead, all three numbers are the same, including the GCWR. Still, I would like to see that number documented somewhere before I drive away with it and hook up my trailer. 2GCVKPEC4K1100671 TIA for any advice! https://cimg1.ibsrv.net/gimg/chevrol...6b103854bc.png |
Isn't the Gross Combined Wt Rating of 15,000 lbs the number you are looking for?
I can't say I have ever seen the CGWR listed as a range. It's the max weight allowed of the tow vehicle and trailer. |
| All times are GMT -5. The time now is 4:06 AM. |
