2500HD 6.0l hard warm starts
Hey new to forum great site by the way been a lurker for years,Anyways have a 2003 2500hd 6.0l with hard starting issue.I have replaced the fuel pump,filter and fuel pressure regulator with oem gm parts and still have hard start issue.It will start cold just like when it did new,but when warmed up wil turn over 4 or 5 seconds before starting. Im totally lost at what it might be any insight would be greatly appreciated.thanks Ty
Do you have check engine light? Sounds like egr or some other related emission issue.
no cel had it tested because didnt trust the cluster and no codes come up except a while back an o2 sensor code came up but hasnt been back .
trying to relate this to a "heat" issue. O2 sensor sets in the exhaust, maybe it, and no code. Intermittent sensor. those aren't too exspensive.
i dont really know but i cant see the o2 sensor being the problem though maybe?
Just picking at the problem, don't know, but I will add just because that part was replaced or "new" dosen't mean it it works (unfortunatley) Unfortunatley the ECM, PCM and how many other mcms. The ecm has to see multiply errors before flagging a code, so, if the 02 is doing it intermiten, and clearing, it might not throw a code.
i took it to a shop a while back and the guy told me it could be the thermostat in the radiator?causing hard starts but it always seems to read right on the gauge though.
What was the cure for this issue? I have the same issue with new fuel pump and regulator already installed.
Originally Posted by George B
(Post 440979)
Originally Posted by Buffalo716
(Post 447601)
Did you figure it out i got same problem
| All times are GMT -5. The time now is 4:25 AM. |
