2500hd steering
my 06 2500hd 6.0 has had a pop in the steering since i bought it its had the intermidiant shaft replaced 3 times! and thats not the fix! is there a bearing i need to replace or something? its righ tup in the steering wheel not down low but if i push the steering wheel hard it has slack in it about an inch.. bearing? the clunk is horrible
RE: 2500hd steering
Are you stating you have an INCH of play at the center of the steering column?(Towards and away from the dash?)
This would not be considered normal, and it sounds like the shaft nut attaching your steering wheel is very loose. In that case, the clunking sound is just a byproduct of a very dangerous condition. See your dealer pronto. |
RE: 2500hd steering
welcome to the forum. welcome to the world of GM cars.
MINE HAS SAME!!! it's not ISS. btw, if you have replaced OEM ISS with exactly same designed, you wasted money twice. It's crappy design and clunck comes back in about 4-5 mths, I KNOW. replace with NAPA one. but, ISS cluck is produced by itself, when you take off or brake down sharply. thud in steering column. what you have, buddy, is what I have - grab steering wheel and shake it, and it rattles like crazy and moves. yes, indeed. so, like I said - get over with and pay no attention. louder music helps. it's their famous quality. |
RE: 2500hd steering
The key to fixing this is actually breaking it, you remove the bottom bolt and then force the shaft up and down then reinstall it, most of the time that fixes it. If not then try this.
http://www.gm-trucks.com/home/Techni...haft-lube.html |
| All times are GMT -5. The time now is 7:28 AM. |
