91 1500k losing power
In July we fired up my truck which had been sitting for about 2 years or so. For the past few months I've been having issues with my truck losing power and dying on me while driving down the road. We replaced the MAP sensor, fuel filter and the fuel pump. It worked fine for about a month and then the same issue started happening. It seems to run fine when I am cruising down the road but if I take off from a stop light, it will act funny and then die. I can usually start it right back up. I have been getting Error Code 44. The injectors appear to spitting fuel properly. May have another bad fuel pump....dunno. Any ideas?
Thanks
Thanks
My experience with power loss on acceleration has been due to simple things like plugged converter, fuel supply, like loose carb plate from the gasket drying out or plugged filter (fuel or air)being you are fuel injected and the vehicle had been sitting I would start with the simple things they are usually cheaper than injectors or fuelpump
Thats just my two cents
We did check the gasket by spraying carb cleaner all around the base. The motor was running and it didn't seem affect it at all. So we didn't think the gasket was bad. We did replace the air filter in the very beginning. We also checked the fuel injectors and they were getting the right amount of voltage. Will see about checking the converter though...thanks!
mshaw130
June 2nd, 2023 6:40 AM
Fightn17
10
April 8th, 2010 12:45 PM
gumbute
December 1st, 2009 10:21 PM
