97 Chevy pickup stock rims issue
So i recently purchased a 97 Chevy pickup that 18" Chrome rims (not the best looking rims in my opinion)
Well I bought some 97 chevy suburban OEM rims with meety tires I wanted to put on the truck. After doing couple of hours of research, i was told by a salvage yard that these would work.
They fit perfect on the rear end with the drum brakes, but the front it wouldnt clear the top of the Spindle i wanna called it. The piece right behind the Disc Caliper, and up a little, i'm not sure what exactly thats called, i was told its a spindle I could be wrong.
Any ideas what the hell is going on here?
Thanks!
Thanks!
wheel spacers are a big noooooooooo...IF you want to go offroading with it.. they will break.. for street use..i dont see why you wouldnt use them.. but for offroad..i'v heard some horrior storys.. also what size are the rims that you got? im not sure if they changed them between 1995 and 1997(doubt it) but i do have 15"s on mine and i have the 16" stock rims that was on befor
Took all the wheels off and threw it up on jack stands last night, began to look at what the hell was going on. Noticed it had spacers on the rear, well what i thought were spacers. They are actually adapter plates that go 5 lug to 6 lug, apparently the previous owner didn't want to take the time to find a 6 bolt rear axle that would work. Now the fronts he took the spindles from what I would believe are a newerish 1500 because the spindles are pretty much jammed in there, They work and everything, but you can tell in certain places they are not the original, which is how i now have 6 lug in the front.
So all in all looks like this winter im going to be looking for some 96 5 lug spindles, to replace mine with.
try calling up some truck junkyards. autozone has a coil spring compressor u can rent. but be sure to check the threads on it. its not hard to change the spindles out unless the coil spring compressor have a boogered thread. good luck.
For Sale: Stock Chevy rims and tires
johntlls
January 14th, 2015 9:11 PM
lookingforhelp
September 29th, 2014 8:52 PM
sollucho
September 6th, 2011 1:55 PM
