97 Chevy Reverse Light Problems
Ok so my reverse light are not working on my truck (97 Chevy K1500 Z-71) and have not worked for awhile. I have checked all the fuses and mad sure the taillight connection was good but I can not for the life of me get the reverse lights to work. Is there a reverse sensor some where on the truck that could have possibly failed? If so where is it and what is the part called cause I have tried doing a parts search and can't find anything. I have also tried finding a reverse relay but have not be able to do so!
Thanks |
does it keep blowing a fuse? or do they just not work? the backup lamps are constantly grounded.. just waiting for power to be applied to them via the light green wire (ckt 24).
here is a wiring diagram. if you have checked the fuse and ground for the bulbs.. then the problem might be the park/neutral position switch. I am assuming your truck is an automatic. hope this helps. http://img227.imageshack.us/img227/2739/62494054.gif |
It is not blowing an fuses. The only lights that do not work are the reverse lights and I have checked the bulbs and the filaments are still good. I will have to prob the GRN reverse power line and see if it is getting any voltage in reverse. If not I am assuming it is the park/neutral position switch, correct?
that is what i would start with.
Ok, Thanks for the info. I will check the voltage of the reverse light connector. I am assuming the park/neutral position switch in located around the steering column.
Nevermind...I found it and the location. All the parts places refer to it as the Neutral safety switch. |
correct, hope you figure it out
auto or stick?
i believe he has an auto.
park/neutral safety/backup switch is down towards base of steering column. kind of a plate looking deal with one or two connectors coming out of it.
97 GMC K1500 5 speed manual transmission
Originally Posted by maxxman04
(Post 136728)
auto or stick?
| All times are GMT -5. The time now is 3:19 AM. |
