98 K1500 - P0300 Random Misfire??
My truck is a 98 Silverado K1500 4x4 with the Vortec 5.7. I have had a CEL for maybe a year now and it has been the rear O2 sensors. One day my truck didn't want to start as easy as it always had. Checked fuel pressure and it was a bit low. Replaced the fuel pump and truck starts up and runs just like before. Maybe a month later it starts idling rough. Read the CEL code and it is the O2 sensors and a P0306 code. I replaced both O2 sensors, plugs, wires, cap and rotor button. Now all I have is a P0300 CEL. I have checked the fuel pressure and it jumps right up where it is suppose to and after I turn the truck off it held the same pressure for over 15 min. I read somewhere on the web that the distributor gear can cause this problem and is somewhat common with this year model motor. I pulled the distributor and the gear appears to be fine. It doesn't look wore much at all really. I have also read that it may be the CSFI and it may be fixed by going to the new system. I really want to narrow it down before I drop $350 on the new fuel injection system and it not be the problem.
Any help would be so appreciated!
Thanks,
Josh
Thanks,
Josh
Thanks,
Josh
Thanks,
Josh
Davidsednothing
December 6th, 2014 9:23 PM
eddiebray73
October 8th, 2014 11:58 PM
