axle ratios
how can i find my axle ratio without pulling the cover?
RE: axle ratios
Welcome to the forum!!! If it has the same gears as when it was new, the code should be in the glove box.
RE: axle ratios
Or you can just jack the rear of the truck getting the back tires off the ground, then make a mark on the drive shaft and spin the drive shaft counting how many times the driveshaft goes round to get the rear tires go around one complete revolution.
RE: axle ratios
look in glove box for code numbers[/align][/align]Rear End Ratio RPO Codes Here [/align][/align]GQ1 -- AXLE REAR, STD RATIO
GT4 -- AXLE REAR, 3.73 RATIO GT5 -- AXLE REAR, 4.10 RATIO GU4 -- AXLE REAR, 3.08 RATIO GU5 -- AXLE REAR, 3.23 RATIO GU6 -- AXLE REAR, 3.42 RATIO G80 -- AXLE REAR, LIMITED SLIP (POSITRACTION) HC4 -- AXLE REAR, 4.56 RATIO [/align] |
RE: axle ratios
Welcome to the forum! Do you still have the options and price sticker that came on the window of your truck? Its printed on there.
Axle Ratio by VIN Code
I have a 2003 Chevy Silverado 1500 Z71. My question is: What feature of the VIN code tells me what my axle ratios are? I gave a local dealer my VIN code and he told me what my axle ratio is. I am looking for a replacement front axle differential and want to understand how to read the VIN codes. I understand the 4th through the 8th digits define features of the vehicle but I want to know what the code is for the axle ratios. Thanks!
| All times are GMT -5. The time now is 6:44 AM. |
