-   Silverado, Sierra & Fullsize Pick-ups (https://chevroletforum.com/forum/silverado-sierra-fullsize-pick-ups-21/)
-   -   belt squeak, but not the belt? help please (https://chevroletforum.com/forum/silverado-sierra-fullsize-pick-ups-21/belt-squeak-but-not-belt-help-please-50265/)
landon101 Apr 27, 2012 10:33 PM
hey all i have a 1997 chevy 1500 4x4 5.7 and ive been hearing a loud squeel while idling and driving so i changed the serpentine belt and also the auto adjustment.."pulley"?( not sure exactly what its called) but the one you can leverage down to take off the belt. Is there something im missing what else could the noise still be coming from?
MDTAHOE Apr 27, 2012 10:51 PM
Take the belt back off and start the truck, is the noise still there?
landon101 Apr 27, 2012 11:19 PM
i will try that in the morning, what would be possible issues if it does or doesn't?
oldchevy Apr 28, 2012 6:48 AM
Try the idler pulley, the bearing may be going bad. Where did you buy the serpentine belt? I changed mine a while back and the noise got worse. After trying everything I could think of, it turned out that Autozone sold me the wrong belt. A little too long.
grumpychevy Apr 28, 2012 8:46 AM
WD40 the front of the alternator and pulley and see if the noise stops. I had this problem and it turne out that a bearing inside the alt was squealing. Had to change the alternator.
landon101 Apr 28, 2012 10:11 AM
i got mine from orielys, though im pretty sure there the same length i compared the old one and the new one
landon101 Apr 28, 2012 10:12 AM
one thing i forgot to ad..after i changed the auto adjustment pulley the noise was more consistent, any thoughts?
oldchevy Apr 28, 2012 10:51 AM
The auto adjustment pulley is called the tensioner. This means that the problem is more likely in the idler bearing or possibly in the alternator bearing.
RacerX Apr 28, 2012 5:48 PM
...even possible, water pump pulley bearing also. Since we arent there we dont know if what you meant is a "squeal" a "squeak" or a "chirp". But all of that could also be a bad water pump bearing too.
cleveland63b Apr 28, 2012 9:54 PM
take the belt off and start it like mdtahoe suggested, if its gone spin every pulley by hand. If anything squeaks or growls replace it, try spinning the alternator by hand both directions or sometimes you won't spin it fast enough to hear
