Cargo Stop Light 99 Silverado
My cargo brake light "on the cab" does not work. The silverado has realitivly low miles, 61000 and in very good shape. I just got it and discovered the cargo brke lights do not work. I changed the bulbs with no luck. The white cargo lights work fine. The brakes lights on the box work fine. Has anyone had this problem or does anyone have any ideas?
Thanks
Brucgraham
Thanks
Brucgraham
Fuses-meter
I visually checked the fuses on the side of the dash. Checked OK. I am looking for a meter to check power at the bulb. I do know there is power at the light assembly because the white cargo lights work fine.
Got it Fixed !
After confirming I had power to the brake light assembly I reliazed that the bulds were not making contact with the brass assembly. Everything was clean and looked new. I wounder if these lights ever did work.I replaced the light assembly and everything works great.
Thanks for the help
Brucgraham
Thanks for the help
Brucgraham
Mojotics
September 2nd, 2020 4:23 PM
marine02xx@yahoo.com
January 28th, 2014 5:33 PM
Mille Racer 69
March 15th, 2010 8:08 PM
