Check Engine Stabilitrak
Please help, we have tried EVERYTHING and are already $1000 deep in parts replaced.
I recently purchased a 2007 Silverado 1500 Crew 5.3L Upon getting home the check engine light came on. Code was P0335 (Crankshaft Position Sensor A Circuit) along with it came the notification for stabilitrak which would also cause rough shifting at low gears and the engine to stall occasionally at idle. Reset the battery/codes and truck runs fine zero issues till code comes back on. We replaced: -Crankshaft sensor and connector wire -Camshaft sensor -Timing chain (tensioner, sprocket, etc) -Spark plugs and wires -Fuel pump (had low pressure and would decrease over time) After this everything ran fine no codes no issues. Took it off the lift and for a test drive and the check engine light is back on and so is StabiliTrak message. Ran the codes and came up as P0335 (Crankshaft Position Sensor A Circuit) and P0455 (Evap Emissions System large leak detected) I am at my wits ends and my pockets are about empty... I don't know what else we could possibly replace. Please help. |
| All times are GMT -5. The time now is 5:32 AM. |
