-   Silverado, Sierra & Fullsize Pick-ups (https://chevroletforum.com/forum/silverado-sierra-fullsize-pick-ups-21/)
-   -   Code 35 will NOT go away!!! (https://chevroletforum.com/forum/silverado-sierra-fullsize-pick-ups-21/code-35-will-not-go-away-44988/)
makingaZJ Aug 28, 2011 8:49 PM
Code 35 is for the IAC valve. I have replaced the valve itself, the harness that plugs into it and cleaned up the grounds on top of the upper radiator hose on my 4.3L.
The "cure" for a code 35 is just supposed to be (replace IAC).
Im just short of getting a new ECM.
Any help before I hopefully dont waste some more money??!!
:mad:
loosebearing Sep 1, 2011 6:47 PM
Did you do a relearn on iacv? Also clean port good where iacv goes .. may have some gunk not letting pentel work right.
kevinkpk Sep 1, 2011 7:16 PM
:mad:
Don't throw your money on an ecm, sensor or needs cleaning ect.
makingaZJ Sep 5, 2011 6:47 AM
Resolution
I forgot to mention that i had my intake manifold gasket rerplaced, the mech that did it DID NOT tighten down my distributer when he put it back in. so through a chain of sequences it was the timing.
