Cylinder order 98 5.7 vortec
I have clicked so may websites now that my poor little mouse finger is throbbing. (boo hoo, right)
Truck was running like crap, so I changed the plugs a nd wire on my 98 Z71 today and it ran much better. But if I got into the pedal really heavy thewhole truck would begin to shudder and it finally through a SES light. Took it to the autozone and had them read the code......mutliple misfire. Next point of attack was the Distributor and rotor. Replaced them both and had a major misfireing thing going on. Thought itmight be crappy parts from Autozone, soI put the original cap and rotors back on andthe problem remained. Hmmmm....I may have switched a couple of wires at the distributor.So my question is, given that the distributor is labeled with cylinder numbers, how do I know which cylinder is number one vs number 8?
That's probably a rookie question, but i had to ask since I've scoured the net and found jack.
RE: Cylinder order 98 5.7 vortec
Very simple, when facing the motor the cylinder to your front driverside is number one then to you front passenger side is number 2.
8D 7 That is how it should look when facing it. and D is Distributor obviously.
6 5Hope that is what your asking.
4 3
2 1
4 3
2 1
1-8-4-3-6-5-7-2 is the firing order and if I remember right, it runs clock-wise around the distributor. Remember you need to have the ignition firing on cylinder number 1 so you know where to start counting on the cap, you understand what i'm saying?
Yeah your first response was the answer I was looking for. I had two of the wires crossed at the distributor. Either the 2 and 4, or the 4 and 6. As you can imagine, it ran like crap.It took me two real good looks at it tofind the problem. After I found the problem I went ahead and switch the distributor cap and rotor back to the new one aswell as changed the ignition coil. Fired right up and runs like a scalded dog now. Better than it has in the 8 years I've owned it, or it least it seems that way to me.I was beginning to getdiscouraged, so thanks for the info.
96k1500
July 14th, 2021 2:00 PM
chance174
January 11th, 2011 12:17 PM
hobieguy
November 1st, 2010 12:25 PM
TMW597
December 31st, 2006 2:17 PM
freight shaker
October 9th, 2006 8:08 PM
