Dash gauges, and PRNDL lights out.
I have an 04 Silverado 2500 HD.
I know the dash clusters have been a problem with this model, but mine doesn't seem to fit the pattern I've read about OR with buddies who've had dash clusters to be replaced. In theirs, some of the gauges would not work. In mine..ALL of the gauges and the PRNDL light will not come on after I crank it....SOMETIMES. Then, out of the blue they'll just come back on while I'm driving down the road. They only go OFF when it's turned off, not while driving. I've found the ground to the battery to the frame and cleaned it up and that didn't seem to make a difference. I will say that recently I had the alternator go out, I replaced that and after the batteries charged for a day or so, they came back on and have worked 99% of the time. But yesterday, they wouldn't come on for 1/2 the day. Then late last night I was driving and BOOM, the dash lit up and they all came back on. Any thoughts? Thanks, Mark |
I'd pull the IP out and re-seat the connectors to the panel... fully unplug and plug them back in... check for any corrosion on the connections...
I'd also check the fuses, make sure they are all fully seated, wiggle them and re-seat as needed. if you search the forum for "instrument" you will find many post with other helpful info... some include howto pictures and part number where applicable :cool: It sounds like what you have is intermittent connection... |
Originally Posted by in2pro
(Post 248542)
I'd also check the fuses, make sure they are all fully seated, wiggle them and re-seat as needed. if you search the forum for "instrument" you will find many post with other helpful info... some include howto pictures and part number where applicable :cool: It sounds like what you have is intermittent connection... I've checked the fuses and even changed em out. This video shows a guy pulling the instrument panel. *Disclaimer, I'm not a mechanic, but I can launch a rocket if I get instructions. :) |
Yep, that is where I would start, its free and a good first place to start...
It could also be a broken trace on the circuit board of the IP or a loose or poorly connected IC device... FYI you can drive your vehicle without the IP installed should you opt to send it out for repair, but keep in mind you will not have any gauges or other informative or important information displays.... i.e. speed, over temp, fuel level... be sure know your fuel level or fill up prior to removal should you take and keep it out for any period of time :eek: |
Excellent.
I'm going to wait until it does it again and stays off for a period of time and check it to see if it restores the power to the IP. It's weird. Sometimes it just fires right up like it's new. Then other days, like today I crank;..it takes maybe 5-10 seconds and then the dash lights up and the gauges all fire up. But before I do anything.... I've got to find my 'Panel Removal Tool'. LOL. |
It's definitely a loose connection or something. I've found that if I just give a little light pat on the top of the dash over the gauges, they come on.
id be banking on the cluster being bad but no guarentees since im not there to play with it
| All times are GMT -5. The time now is 3:47 AM. |
