DTC P1345 Crankcase position sensor
Having trouble clearing DTC P1345. Says its crankcase position sensor correlation? Should I replace the sensor?
usually this means the distributor is off a little. you can't time this motor the standard way. it has to be done at a shop or dealer.
| All times are GMT -5. The time now is 7:42 AM. |
