-   Silverado, Sierra & Fullsize Pick-ups (https://chevroletforum.com/forum/silverado-sierra-fullsize-pick-ups-21/)
-   -   floating gas gauge (https://chevroletforum.com/forum/silverado-sierra-fullsize-pick-ups-21/floating-gas-gauge-10328/)
bwaddell Oct 16, 2007 12:45 AM
floating gas gauge
What would cause your gas gauge to float when your truck is in park and your idling. PLEASE HELP!!!!!!!!!!!!!!!!
biggame Oct 17, 2007 10:36 AM
RE: floating gas gauge
I have a issue that is similar. When my 2001 5.3 Z71 is totally full on gas it will drop totally empty and the gas light comes on. Then if I put into drive or hit a bump it comes back to full. It only happens when it is full. Strange,
p.hinds Oct 17, 2007 6:01 PM
replace the level sensor in the fuel tank
Kevin Oct 19, 2007 5:32 PM
drop tank, remove and replace float, pump, and sensor.
jimmydaleo Oct 19, 2007 5:49 PM
Might be easier and cheaper to get a whole sending unit. should be one piece. find part number and comparable models used. might get ebay or junk yard
bwaddell Oct 19, 2007 11:50 PM
hey fellas, i think i just need to get a new fuel pump and problem solved right.
[/align]
Kevin Oct 19, 2007 11:55 PM
its in the tank
bwaddell Oct 20, 2007 12:00 AM
dont quite follow you
[/align]
Kevin Oct 20, 2007 12:03 AM
fuel pump is the "sender" unit. it is located inside the fuel tank . that is where the float that measures your fuel level is attached.
bwaddell Oct 20, 2007 12:12 AM
i get that
[/align]
