Fog lights
I have a 2002 Silverado. I have all I need to put after market Fog Lights on it. Where are the wires underneath the front to connect the harness? I already installed the switch and relay.
If the truck wasn't setup with fogs from factory the pugs aren't there...gotta add em
did you get the kit from the manufacturer? they probably won't just plug in if not
I don't need the plugs. I have them. I just need to know where to look for the wires to splice them into.
If they're in there, they're runnin in a wire loom that runs on the frame right under the fan shroud
Thanks, I will look there when I get a chance. Work a crappy schedule so weekends are better for me with this project.
| All times are GMT -5. The time now is 8:40 AM. |
