Help!!! Accessory power outlet not working!
I was using a portable 12 volttire inflator to put air in tire. After about 5-10 minutes tire inlator stopped working. I did not have engine running while powering inflator. The inflator will work in cig lighter. Checked the aux power fuse and it was ok.Arethere any other fuses in connection with the accessory power outlet? Any info would be appreciated. Thanks
RE: Help!!! Accessory power outlet not working!
i had that happen to me. i checked the fuse i thought it was and it was fine. it turned out to be another fuse. that happened to me about 3-4 times while using a power inverter
Do you remember what you did to fix it? Thanks
i just kept double checking fuses, found out which one it was, and put a high amp fuse in there. i dont really know if thats the same problem youre having though. i wish i could be more help. i am sorry.
It maybe the tire inflator. Some are built to cycle off after 10 minutes so it can cool down for 10 minutes. Just a thought
good idea...
ORIGINAL: engine2 It maybe the tire inflator. Some are built to cycle off after 10 minutes so it can cool down for 10 minutes. Just a thought |
Aux power outlet is bad. Buy a new outlet & bezel for about 12 bucks from GM.
st an idea but check your compressor in another vehicle ,also some of the accessory cig lighter power plug's have fuse's in them !
Damn
Outlet won't trun on. ...
| All times are GMT -5. The time now is 1:12 AM. |
