-   Silverado, Sierra & Fullsize Pick-ups (https://chevroletforum.com/forum/silverado-sierra-fullsize-pick-ups-21/)
-   -   Hydrogen Generator (https://chevroletforum.com/forum/silverado-sierra-fullsize-pick-ups-21/hydrogen-generator-17194/)
flyoil Jul 24, 2008 12:30 PM
Hydrogen Generator
I have a 2004 Silverado with the 4.8 motor. I get 20 city and 26 Hwy with the tailgate down.
I am installing the HHO Generator but I need help as I need to find a positive feed in the fuse box ( I believe there is a large fuse box in the engine compartment next to the battery) that turns on and off with the engine (ignition). It is imperative that it does not turn on if I have the key on accessory as the HHO Gen. will start working when the engine is not running and that is a big no-no.
Any help will be appreciated. thanks.
Streaker Jul 24, 2008 3:43 PM
RE: Hydrogen Generator
You shoudn't have to hook it to the fuse box just any item under the hood that switches on with the ignition.
How about the windshield wiper motor?
I don't have a manual to your truck but you should be able to buy a haynes manual and it will give you an electrical schematic and tell you what you need to know.
Good Luck. Do you also have the mapp sensor enhancer?
flyoil Jul 24, 2008 4:58 PM
that makes sense. Yes, I bought the Haynes manual and it is extremely informative. However, I don't feel comfortable dealing with electricity, wiring etc.The last thing I want to do is short something out. - I think what I will do is go to a shop that deal with electronics etc and ask them to help me out, or maybe even a place that intalls stereos.
Yes, the HHO Hydrogen kit I purchased comes with a microprocessor control system.
jkgray80 Jul 24, 2008 5:38 PM
Installs stereos? Take it to a real shop if you are unsure on how to hook it up.
shawnvw Jul 25, 2008 2:56 PM
If I were you I would hook it up the the fuel pump circuit with a relay so your sure it will only run when the engine is running. If you go to ignition, it will still run if you turn the key on without starting the motor
northey87 Jul 26, 2008 8:27 PM
I second, on the the fuel relay.
kmatassa Aug 3, 2008 3:48 PM
curious as to the outcome and performance of this mod.
Flyoil can you expand?
thanks
flyoil Aug 3, 2008 8:15 PM
Yes, I will be posting additional information as soon as I receive the kit. I am supposed to be getting it sometime this week.
itlldue Aug 5, 2008 10:05 AM
Put in a Hobbs 7psi NO two terminal oil pressure switch to run the circuit through. No oil pressure, no HHO generator.
itlldue Aug 5, 2008 10:07 AM
By the way, be sure and call your insurance carrier and tell them that you have installed a Hydrogen Gas Generator on your vehicle. That way if they void your liability coverage, it's not a surprise to you.:)
