Need Desperate help
1990 Chevy Pickup
Drove it to work one night. came out in the morning, and it wont start. have replaced dist cap, plugs, wires, filters. The plugs are not getting fire. not an issue for fuel. we are not getting it to fire. any suggestions? :confused::confused: |
Coil? Is the Dist. turning. Showing any codes?
replaced the coil.... and the ignition module was tested and it is ok.
my cusion had a bad ignition module and it didnt give spark to the plugs bought a new one of those ran for a day and then back to square one same problem so were going to try to change the distributer cap he has new plugs and wires also dont know if this helped any but might be a start for you
Check the wires on your starter, i had the small ignition wire brake a few years ago and it sounds close.
I hate these kind of headings and won't read the cry for help. The least you could do is give a clue to your problem.
| All times are GMT -5. The time now is 9:31 AM. |
