-   Silverado, Sierra & Fullsize Pick-ups (https://chevroletforum.com/forum/silverado-sierra-fullsize-pick-ups-21/)
-   -   Need help with emissions problem on a 1987 silverado 5.7 tbi (https://chevroletforum.com/forum/silverado-sierra-fullsize-pick-ups-21/need-help-emissions-problem-1987-silverado-5-7-tbi-30176/)
Heinousacts Feb 9, 2010 1:16 PM
Hello my truck recently failed the low speed test on both co and hc.
I have replaced the cap,rotor,plugs,wires,and air filter and it is still failing.
Any ideas where to go next?
mudmaniac Feb 9, 2010 1:24 PM
Try advancing the timing a few degrees and have it re tested.
maxxman04 Feb 9, 2010 1:26 PM
oxygen sensor, catalytic converter, muffler. check for exhaust leaks, vacuum leaks. maybe even replace gas cap if that hasn't been done for awhile.
Heinousacts Feb 9, 2010 1:44 PM
The timing is advanced 2 degrees, and the guy at the emissions said it would be failing a different test if it was the cats or exhaust. I checked the three vacuume lines at the throttle body and they seem fine.
I did notice today the there are only 2 lines plugged into the canister, does anyone know where to find a diagram that shows where all the lines from the charcoal canister should run to?
