Not starting
#11
Pull the top off the carb, if there is no gas in the float bowl, replace the filter. To check the pump, remove fuel line to carb, with a can or something to catch it, crank engine (I assume it is a mechanical pump). If you get gas, it isn't the pump.
You probably would be wise to check the pump first.
#12
i cant remember off the top of my head. but its either 45, or 50-55 psi... if it is not there then you do not have enough fuel pressure for the car to start. check your fuel filter, although it will most likely be the pump.
#13
45 or 50-55 psi would be for fuel injection. For a carb it would be 6-7 psi. If this truck sits outside then climb underneath it starting at the tank and have a look. If it has an electric fuel pump it could be as simple as a critter building a nest on top of the tank knocked a wire loose a chewed on the rubber part of the fuel line. Maybe dry rot from heat and age. Change fuel filter.
#15
krustyjonez
May 17th, 2011 8:02 PM
payshoot
December 5th, 2005 9:54 PM
heil810
November 22nd, 2005 3:47 AM
