Opinions on some tires and lift.
I got a '95 Z71 and am looking at a set of 33x11.50 M/T's and was thinking about putting a 3" suspension lift on it. Do yall think that is too much of a lift for these tires? Here is a link to the tires i am getting. I like the look of the tires but want my truck a little higher too. Thanks for the input!
3" would probably look good.. i got a set of 33"s on my truck now without any lift.. but u might want to research if the 3" and the 6" might be the same amount of work..u might as well go with 6" if i is..
i'm not gonna do a 6" lift with 33's for 2 reasons, first it would cost me out the *** wheras i'm a sophmore in highschool at the moment, and i think it would look odd lifted so high with only 33's and i would get 12.50's but i found some good quality tires, for realativly inexpensive so i'm thinkin about doing the 3" key and block, 33x11.50, powder coated rims, and bushwacker fender flares, opinions?
if you do the 11.50s don't get the fender flares..your tires won't stick out enough for the flares to cover it unless you get a huge negative offset on it....with my 12.50s i got a -12 offset and my tires only stick out maybe a inch and personally if i were to put flares on it i think it'd look retarded
mr.dudeman199
18
May 20th, 2013 6:36 PM
RoflCopter726
March 14th, 2008 10:19 AM
