Split A/C problem
Split A/C problem
Gentlemen: My 2004 3/4 short crew has developed a nasty problem. The left (driver) side a/c will intermittently kick into high heat output while the right (passenger) ducts keep pumping out nice cold air. Shutting down (engine off)for ten minutes seems to fix, but that doesn't work well when I've got to pull the Scout's trailer from Kansas to So. Dakota for summer camp next month. Dealer sold me a < $100 software upgrade that did nothing. Claims next step is nearly $1000 job on duct motor (?). Any suggestions? It's hot here.
RE: Split A/C problem
I'm at least glad I'm not the only one with this problem. The same occurs with mine if the AC is not on with just vent air. I haven't found a solution but I do have a fleet group with a lot of chevy pickups in it and one afternoon, we swapped the dash switch out - no change and next we took off the vent box below and I found a loose wire clip but alas same problem. I'm waiting for others within our fleet to have the same problem and see what they do and I need them to ask the chevy tech reps for a solution. Sorry no answer at this point
Steve L.
October 1st, 2011 12:44 PM
kawik1500
November 12th, 2010 10:56 PM
gregoryboen
August 31st, 2009 11:18 AM
For Sale: New 67mm Turbo T4 split inducer hotside
willyod
August 22nd, 2009 2:18 AM
