Starts then dies code 35?
Hello everyone!
Got a bit of a problem here, hoping for some help Recently acquired a 94 chevy silverado c1500 to help me move. Has been great till today..... Went to go to the gas station, started the truck ran for a couple seconds then died. Tried again, it started ran for 5 seconds and died again. Looked up how to check the codes and got 35 the first time ( idle air control sensor circuit fault ). Started looking around for obvious faults, loose battery cables, wires unplugged and such with no luck. Tried once again, it started i held the rpms to 2.5k and it ran till warm. I tried letting it idle and after about a minute or two and it died... Is this code relevant to these symptoms or does anyone have any experience with a similar problem? And since i dont have a book for this truck yet. Where is it? lol idle air control sensor ^^^^this |
I believe that the sensor is built into the IAC valve, you may simply need to remove and clean it.
well i changed the whole sensor this morning... still doing it. So i guess that wasnt the same problem. Any ideas?
was the module
| All times are GMT -5. The time now is 6:09 AM. |
