Steering, Power Programmer, Headers
I have a 1998 Chevy Silverado 1500 Z71 5.7L pickup. Out of nowhere my steering will just loosen up and jerk to the side. I heard once about a possible speed assisted steering box and was wondering if anyone had any experience with these or know if there is one on the truck, or if there is another problem causing it.
Next I was wondering what people thought would be a good power programmer for this year and model. Finally I was looking into headers and was wondering what the difference between putting 1-1/2" and 1-5/8" headers. My exhaust set up is stock exhaust manifolds into a stock y pipe and then i just have a single tube exhaust w/ a flowmaster muffler. I think it is 3" but im not sure and would that even matter?? I was also planning on putting on a K&N air filter. Let me know what ya'll think. Thanks |
Did you find out what the deal was with the steering? Mine does the same thing. I've replaced ball joints, tie rod ends, etc.... didn't fix the problem.
Originally Posted by jcureton
(Post 84694)
My '97 had the same issue, in a turn, sometimes it would feel exactly like you hit a patch of ice... what was causing it was a faulty variable assist sensor. Your vehicle has more or less steering assist depending on speed. You suddenly go from low boost to very high and subsequently, it feels like it jerks, or you hit ice. It's not terribly expensive part, you should be able to do it yourself, I went to a dealer. The biggest problem with this is, the sensor now gives me too much boost at speed. Not like before when it would suddenly go to full on, but more than I'd like at highway speed. I remember my '89 Silverado was much firmer steering and was one of the things I really liked about that truck. I would like to know, and found this thread looking for... is it possible to "tune" out the boost at highway speed? I'm sure it's controlled by a computer somewhere on the truck.. Thanks in advance! Shortz |
Originally Posted by 98Silverado1500
(Post 84567)
Next I was wondering what people thought would be a good power programmer for this year and model. Finally I was looking into headers and was wondering what the difference between putting 1-1/2" and 1-5/8" headers. My exhaust set up is stock exhaust manifolds into a stock y pipe and then i just have a single tube exhaust w/ a flowmaster muffler. I think it is 3" but im not sure and would that even matter?? I was also planning on putting on a K&N air filter. Let me know what ya'll think. Thanks I guarantee you will say the same. Its a little stiffer when you are in parking lots or going slow, but nothing that you would really notice or consider to be wrong. But when you are a highway speeds, its steady as a stone. Let me know if you try it, and how you like it. |
(Post 187449)
I ended up taking the steering speed sensor off, and it was perfect!
Would it be so simple to just unplug the darn thing??? That would make me have a very :) happy face! Shortz |
Originally Posted by Shortfork
(Post 187561)
Other than the spoungy brakes and the overly light steering at highway speeds (much lighter than my previous truck '89) I love this truck!! I'd like to just remove the sensor but doesn't the system default to full boost then? When it was failing a few years back and I had the "yanks"... I thought I read that when the sensor fails, it does go to full on... which certainly seems the wrong way to default..
Would it be so simple to just unplug the darn thing??? That would make me have a very :) happy face! Shortz I don't have that truck anymore, and I can't remember if I ever tried disconnecting it. I should be easy to try though. I seem to remember that it was a little tricky getting it off the column, maybe a a hidden screw or something. It didn't take long though. I remeber that I had spent days replacing shocks, ball joints, tie rods, wheel bearings and it ends up being a stupid sensor that took just a few minutes to remove. Best of luck with it. Let me know.... |
| All times are GMT -5. The time now is 4:57 AM. |
