sticking brake
hi guys, reelal here, a newbie.
i have a1982 chevy 4x4 6.2 diesel with a sticking right front brake. have replaced the caliper & the hose bled it and it still sticks. could the proportioning valve cause this? when i replaced the hose fluid did not run out. if it was the master cylinder would not more than one brake lock-up? any help would be appreciated. |
Did you clean the surfaces where the caliper slides on (The guide pins) And lubricate them?
A bad master cylinder usually goes to the floor. I think a proportioning valve would be either a front or rear problem not just one front hanging up bleed the whole system. and see if that helps. |
| All times are GMT -5. The time now is 5:54 AM. |
