-   Silverado, Sierra & Fullsize Pick-ups (https://chevroletforum.com/forum/silverado-sierra-fullsize-pick-ups-21/)
-   -   towing capacity (https://chevroletforum.com/forum/silverado-sierra-fullsize-pick-ups-21/towing-capacity-31907/)
acc2108 Apr 4, 2010 11:51 AM
towing capacity
i nedd to know what the max towing capacity is for a 2004 silverado 1500 5.3L
s34n Apr 4, 2010 2:45 PM
book should say. do you have 2wd or 4wd?
wellmax Apr 4, 2010 9:38 PM
to determine your tow capacity you will also need to know your differential ratio.
the code is listed on a tag in glove box on many models.
fine your code and someone on forum can tell you the ratio number.
s34n Apr 4, 2010 10:37 PM
Gq1 -- axle rear, std ratio
gt4 -- axle rear, 3.73 ratio
gt5 -- axle rear, 4.10 ratio
gu4 -- axle rear, 3.08 ratio
gu5 -- axle rear, 3.23 ratio
gu6 -- axle rear, 3.42 ratio
g80 -- axle rear, limited slip (positraction)
hc4 -- axle rear, 4.56 ratio
davbell22602 Apr 7, 2010 9:12 AM
Look at GCWR rating thats on the rpo sticker in the glove box.
s34n Apr 7, 2010 6:31 PM
or check that rating on your door sticker
