-   Silverado, Sierra & Fullsize Pick-ups (https://chevroletforum.com/forum/silverado-sierra-fullsize-pick-ups-21/)
-   -   Tranny Cooler (https://chevroletforum.com/forum/silverado-sierra-fullsize-pick-ups-21/tranny-cooler-51812/)
joe in calif Jul 11, 2012 9:27 AM
Tranny Cooler
The 2000 silverado 1500 I bought has a 5.3 V8 and it came with the tow package. My question is, does it have a transmission cooler from the factory? What do I look for to see if ut does or doesn't? Thanks again
oldchevy Jul 11, 2012 10:47 AM
They come with a factory transmission cooler. It might be wise to add a transmission cooler if you do a lot of towing.
joe in calif Jul 11, 2012 1:34 PM
Thank you, I plan on using it for towing so I will look into adding one.
isrummell Jul 11, 2012 7:49 PM
the towing package should come with an up graded cooler
ericnottelin Jul 17, 2012 1:38 AM
Ok, I have a question. My 08 has a really small external trans cooler. All the tranny lines are pressure fitted lines. So how do you install a secondary, larger cooler?
isrummell Jul 17, 2012 6:29 PM
im looking to add one to my truck. but im not sure as to where to put it and how do u hook it up, in series or parallel
cleveland63b Jul 17, 2012 7:53 PM
most of them should come as a kit with everything you'd need
isrummell Jul 18, 2012 6:10 AM
but where do u mount it? i dont have much room between the radiator and the grill on my truck
oldchevy Jul 18, 2012 2:44 PM
You would hook it up in series and try and put it somewhere that has air flowing around it to help keep it cool.
country_09 Jul 18, 2012 4:35 PM
no need for 2 tranny coolers. Look into a tru-kool 40k cooler. They're the best of the best and make the stock tranny cooler look like a paper weight.
transmissioncoolers.us: Tru-Cool MAX transmission cooler *No external cold weather thermal bypass
comes with everything needed to install. Might want to get a tranny temp gauge if you tow that much.
