Trans not shifting speedometer not working
Truck just started acting up. When on drive it does not shift. I can manually drive in first and second, not third. And the speedometer quit working as well. Buddy thought it was the shift selonoids so changed those still nothing. Any ideas?
It would help if you fill out your profile so we know what truck/trans you have.
Possible busted sprag in the forward sprag assembly. Do you have Reverse? What vehicle, engine and trans?
Originally Posted by KChevy75
(Post 306577)
Similar problem
Im new to the forum and a first time suburban owner. It's a 1999 k2500. One day the speedometer quit working. And I noticed reverse gear seemed to be slipping. The next day, no reverse gear at all. I've replaced the transmission output sensor. Crickets. I noticed a couple ground straps had rusted in 2. I replaced them, no luck. And now I've noticed I don't have low gear. I have D, 3rd, and 2nd. It's a 4L80-e transmission. And wisdom will be greatly appreciated. You don't realize how much u need reverse until u don't have it. Lol
| All times are GMT -5. The time now is 4:16 AM. |
