Transmission problems
i am having magger leaking under my truck (transmission) it is leaking. The dealer said i need to replace the bearing and the seals. I was wondering if i can replace the bearing without droping the transmisson?
O and it is a 2000 4x4. Single cab 6.0L.
RE: Transmission problems
[hr]Nope! You gotta drop the trans. If you intend to keep the truck and it has over 100K on it, it is more cost effective in the long run to rebuild the trans since you have to drop it anyway.
how many miles are the truck.. yeah you are going to have to drop the tranny, transfer case, and drivshaft to replace the seals unfortionally
2003 silverado ext cab Z71 5.3ltr
1989 c1500 shortbed reg cab 350ci
Coravir
October 26th, 2019 3:28 PM
DSGB
May 29th, 2013 8:54 AM
