-   Silverado, Sierra & Fullsize Pick-ups (https://chevroletforum.com/forum/silverado-sierra-fullsize-pick-ups-21/)
-   -   Transmission Woes (https://chevroletforum.com/forum/silverado-sierra-fullsize-pick-ups-21/transmission-woes-68692/)
goadus Oct 22, 2014 7:04 PM
Transmission Woes
I have a 1999 Silverado 4wd with 200,000 miles. While driving it this morning it made a weird noise like a klunk or something. I was driving about 60mph and had been driving all morning. After the noise it made I could give it a little gas and it would rev up and then "catch" gear. When I got to my destination it would not go in reverse. Any ideas what it could be? It's all good in drive just no reverse. I tried searching for this but no luck.
Allan In NE Oct 23, 2014 6:16 AM
Yes Sir,
The reverse input shell has stripped. The transmission has to come out for repair. About a $100 repair if you find the right guy to do it.
Allan
http://i57.tinypic.com/10ghemu.jpg
goadus Oct 23, 2014 6:13 PM
I read that 2nd and 4th gears will be out along with no reverse. So I tried it out today and sure enough no 2nd and 4th
Allan In NE Oct 23, 2014 6:27 PM
Yep,
That shell carries the torque of the over driven gears (2nd & 4th) along with reverse.
That shell will cost in the neighborhood of $40 and these shops are gonna try to soak you BIG bucks to replace it; $1700 to 2 grand.
The last one I did back in February, I charged the guy $200 and pocketed $100 of it for my 2 hours labor.
Allan
goadus Oct 25, 2014 11:07 PM
I have found a 4l60e from a 1998 and 1999 s-10. Will either one work in my Silverado?
Allan In NE Oct 26, 2014 12:44 PM
Hmmm,
Probably if you don't crowd it. The S-10 versions are built lighter, especially reverse. Make sure it is for a 4x4 also; S=2x and T=4x4.
Allan
goadus Oct 26, 2014 6:19 PM
Originally Posted by Allan In NE (Post 287679)
Hmmm,
Allan
Thanks Allan, I'll be sure to check that.
NealSS Oct 26, 2014 7:50 PM
Actually the S-10 Trannies uses exactly the same clutches As the 1500 Not Weaker or stronger
NealSS Oct 26, 2014 7:51 PM
If its not a 4x4 just change the back housing from your tranny
