True or False
True or False
Is there a quick way to tell if an engine has low miles without tearing it apart? I always get scared when someone wants to sell me an older engine with very low miles.
How accessible is the engine? Pull the valve cover, if it's low miles, it should look it.
Is the engine still running in the truck? If there's a tachometer, watch the engine at idle.
On a low-mileage engine those nylon timing chain gears won't have sheared off many teeth, and you should have a smooth idle.
Pull the distributor cap, once again, if the engine is low miles, it'll look it.
Ride of the Month
May 2009
Ride of the Month
May 2009
ROTM Coordinator
ROTM Coordinator
Was it in a wreck? is it still in the car? if so I bet the mileage is correct, unless they are just making stuff up to sell the motor.
I wonder if you can get the vin # and look up when it was filed a non-op. at the DMV, MVD or whatever they call it where you are.
Good Luck!
Good Luck!
