wheel hub and ????
#11
pretty sure the complete abs speed sensor and reluctor wheel are all part of the new hub bearing assembly.
the rim scratch:
looks like the rim was hitting the rotor; probably was installed on a vehicle with a bigger brake package or different rim offset.
the rim scratch:
#13
ok, truck is running good so far, i replaced the wheel hub assembly and the cv axcel shaft.
i went ahead and ordered another wheel hub assembly for the drivers side, i figure it won't take long for it to fail. my question is, should i replace the axcel too?
so my question is, should i have to get it aligned? Its not pulling or anything...
#15
technically you shouldn't need an alignment after just replacing the hub but I'm assuming it hasn't been done for a very long time since your hub got that bad so it definately wouldn't hurt
Stevoray81
October 30th, 2014 10:30 PM
hairscrambler
February 25th, 2014 1:48 PM
jwko
December 12th, 2008 9:33 PM
