Involvement of the front fog lamp Aveo (Sonic) T300
9 Attachment(s)
Hey guys already know where to ask. I kept engage front fog lights from one service firms. Fog lights were purchased as unoriginal but everything fits as a light bulb and it's just the same as the originals.
So they exchanged a plastic housing and installed fog lights and pulled extra cabling because the car was not preparation for a front fog lights, and here is my problem. I wanted to make it from the company involved as it is the factory that lit up the light on the dashboard and switch worked just as it should be. When I pick up the car, so I argued that a switch which I supplied them does not work. But the connector wire is already ready. But I've found and compared with another Chevy that the switch works, but the lowest in the connector that is connected to the switch, one wire, and I suppose it's switching to those mentioned fog because everything else is working as it should. I attach photos. I would be grateful if someone could explain or something similar already solved where I connect the wire and if you happen to low- and fuse boxes already prepared The relay or where to connect. |
