Spark plug installation questions...
what is the allen size for the cover bolts (4) removal? Correct gap? Thanks.
What year,model & engine size are we talking about?
'06 aveo 5,I-4 1.6,34000 mi.
Hello, I am thinking about changing just the spark plugs (no wires) on my 04' Aveo myself. It has 34500 miles. I have done this before on my previous cars but not on the Chevy. Is there anything specific I should pay more attention to or is there any free repair manual for '04 Aveo where I can double check that I am doing everything right?
What spark plug brand would you recommend for my car? I am cosidering the following spark plugs: Autolite-the cheapest Denso Bosch NGK Thank you in advance. |
Go to autozone.com you'll have to register to their site, but once you do you can go to the repair info and it will give you step by step instructions
shepodog25, thank you.
Originally Posted by kanapa
(Post 105155)
pzsamscore, I did exactly what you are saying. I read somewhere (could be here in the forum) that the original spark plugs are NGK. Therefore, I bought NGK (the cheapest ones). The old ones were NGK which confirmed what I had read before I started replacing them. All I can say is that the old ones were in a great condition with no signs of improper engine misfiring or other symptoms. With the new ones, the engine works great even though it was working just fine with the old ones, I did it because it was due according to the vehicle maintenance schedule. Also, I did not measure ot adjust the gap but it seems to be the right one since the engine is working as good as before. I had hard time getting the old ones out because they all were stuck (kind of ceased) but with a more effort I was able to get them out. It is good that I had that special swivel spark plug socket/wrench with a thick rubber ring at the bottom that would pick up the spark plug and pull it out once unscrewed. Even a littlel late, thanks for the post.
I've tried installing new plugs on my ride. But i quite screwed up with the spark plug wires. So my friend mechanic installed them instead. He used NGK plugs and it was good.
a little help when replacing plugs and wires...
put a little anti seize compound on the plug threads before you install them. just enough to lightly coat the threads.. get a small tube of dielectric grease. when putting your wires back on, put about a 1/8" line from the bottom of the boot to the top. take the boot and pinch it between two fingers, and that will evenly spreed the grease in the boot..then reinstall. do this in plug end, and coil end, it will make things easier next time you have to change them.. hope this can help someone.. good luck. |
