-   Sonic (Aveo) (https://chevroletforum.com/forum/sonic-aveo-11/)
-   -   Thermostat housing (https://chevroletforum.com/forum/sonic-aveo-11/thermostat-housing-32033/)
BlackAVEO Apr 8, 2010 12:07 PM
Thermostat housing
I have read many complaints about the thermostat housing on the Aveo. It happened to my wife about 3 weeks ago and her story no different from the rest. She was driving and suddenly she saw a cloud of smoke. She thought it was the car in front but it was the Aveo spraying anti-freeze on a hot engine.
I ordered the thermostat housing which came with the thermostat and gasket. Is there a certain way the thermostat has to be positioned. I don't see an indicator and I can't seem to find a Haynes book on Aveo's. Is there an AIR bleeder valve, Please help
dleebold Apr 13, 2010 8:27 PM
metal housing
http://www.ehow.com/how_6124002_repl...hevy-aveo.html +call auto zone and ask,they will help.
therewolf Apr 24, 2010 5:56 PM
Check the "help,help" thread in this section...
wittk129 May 29, 2010 2:13 PM
Chevy Aveo Thermostat housing
I would like to inform everyone that has problems with there thermostat housing cracking or blowing out!! Auto Zone is now carrying a METAL part called a Water Outlet that replaces the plastic thermostat housing. It is only $37 dollar and works great. And it is two pieces so you are able to replace the thermostat if it goes bad. And my husband said it is alot easier to put on!
aquaaveo Aug 16, 2010 10:51 PM
I am with you wttk
I put the AutoZone metal thermostat on my car. Very happy with it but, they did not have it in stock and took three days to get one in. I did make my old one last, if you have a lot of miles, mine went out at 127K miles, I would see about ordering one and just take the 20 mins and do it as preventative maintenance.
jrosepol Apr 14, 2015 1:23 PM
thermostat housing
Where is the thermostat located on the 2011 model. I know previous model it's on the passenger side of the block facing the radiator.
Yas Tsubaki Aug 17, 2015 4:34 PM
Thermostat housing is problem but on coolant sensor housing plastic that crack my car coolant leak out my 2010 aveo LT this car suck bad material (use aluminum Chevy )
