02 sub leaking coolant
i have a leak somewhere, it dosent look like its coming from the top of engine, hoses dont show any signs of fluid, on the underside i see the fluid around the oil pan, is there a seal or water pump in the area, please send any suggestions.
Thanks
Thanks
RE: 02 sub leaking coolant
Sounds like the water pump is leaking. Thats why mine did. So much stuff in the way its hard to see anyting but I kept seeing the coolant on the underside. I would suggest to replace the belt tensioner with it sing you have to take it off anyways. Mine went bad 10,000 miles after I did the water pump.
isaacsnr07
January 12th, 2010 9:36 PM
SuperTexan
October 30th, 2008 8:12 PM
