07 Chrome strip and other changes
Old April 23rd, 2008, 8:40 PM
  #11
tahoe07's Avatar
Default RE: 07 Chrome strip and other changes
The tow hooks are GMs. The PIA is the access to the bolts. On the passenger side there just isn't room and you have to get in contorted angles with your arms. Have lots of short and deep well sockets as well multiple wrenches all of the same size. The more options you have for starting and finishing each bolt the better.
I have the molded GM splash guards too. Be sure to get the ones you need. There are different ones for the front depending on if you have the boards or not.
Watch shipping below. It may be cheaper to go to dealer!
front molded with flares...
http://gmaccessoriesstore.com/splash...th=35_36_44_46
rear molded...
tow hooks...
http://gmaccessoriesstore.com/hooks-...th=35_36_44_46
Old April 23rd, 2008, 8:45 PM
  #12
tahoe07's Avatar
Jmitchell,
You are right that the 3/4 inchdoesn't completely cover the rear but it covers most and the 1" isn't available in stores.I think someone found it on-line but it was special order and you had to buy way too much. Maybe we could split a purchase.?
Quite a few of us have used the 3/4 inch and there is no GAPwhen you put it against the painted portion and leave the Small area of exposed at the top. It looks best, is easy to keep straight and tends not to get peeled off as items scrape across the step pad because it is down from edge a little.
5.0stang
June 16th, 2022 7:46 AM
Satyr
July 12th, 2013 4:21 PM
biglg
September 28th, 2009 9:58 AM
dmetcalf
June 18th, 2009 3:35 PM
Quick Reply: 07 Chrome strip and other changes
