07 Tahoe low Voltmeter reading
anyone else notice a low volt or is it just my truck
RE: 07 Tahoe low Voltmeter reading
Black check out my post regarding my battery issue.
cool thks
This is normal.
Starting with the 2005 model year, light duty full size pickups and utilities, are equipped with a new Regulated Voltage Control (RVC) system. This system turns off the alternator when it is not required in order to improve fuel economy. The alternator will turn back on when additional voltage is required. This will cause the voltmeter to fluctuate between 12 and 14 volts as opposed to non-regulated systems which usually maintain a more consistent reading of 14 volts. This fluctuation with the RVC system is normal system operation. |
ORIGINAL: ZX1100F1 This is normal. Starting with the 2005 model year, light duty full size pickups and utilities, are equipped with a new Regulated Voltage Control (RVC) system. This system turns off the alternator when it is not required in order to improve fuel economy. The alternator will turn back on when additional voltage is required. This will cause the voltmeter to fluctuate between 12 and 14 volts as opposed to non-regulated systems which usually maintain a more consistent reading of 14 volts. This fluctuation with the RVC system is normal system operation. |
ORIGINAL: ZX1100F1 This is normal. Starting with the 2005 model year, light duty full size pickups and utilities, are equipped with a new Regulated Voltage Control (RVC) system. This system turns off the alternator when it is not required in order to improve fuel economy. The alternator will turn back on when additional voltage is required. This will cause the voltmeter to fluctuate between 12 and 14 volts as opposed to non-regulated systems which usually maintain a more consistent reading of 14 volts. This fluctuation with the RVC system is normal system operation. thanks for your help... |
