07 tahoe rattle
when i turn key to the on position i hear like rattling noise from top driver side of the engine. then turn key to off position and makes the same noise.
it is something that turns on and off before ignition. im stumped Ideas are much appreciated |
Has your washer fluid heater been disconnected?
I think so
ill check it out i do remember that recall back when it came out i think they ended up giving everyone a 100 dollar check if i remember correctly but ill check it and go from there, i just put a new oil pump in her its definitely something that gets primed or turned on when the key is on but not started. maybe fuel pump going out? |
Try listening w/ hood up while someone else turns the key. Might be able to localize it.
Doubt it's the fuel pump since it's in the tank. |
Originally Posted by 73shark
(Post 236769)
Throttle body throttle plate motor ?
it quit making the noise
but thats what im thinking is the throttle motor its like a rattle snake with metal lol |
