'08 Tahoe LT Grinding Noise
I have a 2008 Tahoe 4WD that has just recently started making a real low grinding noise on start up / Cutting A/C on. Not sure what this noise is, My suspicion is that it may be coming from something to do with the A/C. My dealer heard that noise when I took it in to them but they do not know what would be causing this. Anyone else out there experiencing these grinding noises on start up, etc??? ANY help and/or advice would be GREATLY appreciated.
Is this the noise? http://smg.photobucket.com/albums/v6...27-08_1118.flv
If so, have the Dealer reference GM Document ID #2022356; the fix for this is bulletin 07-01-38-010 and it is the reprogramming of the ECM. Thanks to the great info from this Forum, the ECM reprogram fixed this problem on my '07 Suburban - and I haven't heard it since! Good luck. |
I have that same problem, the sound isnt constant, it happens when it wants to, its annoying and loud! When I get home Ill listen to the audio file to see if its the same noise
Search the forum for this. One suspect cause was the A/C compressor.
Willys 53 that is the noise... I will call my dealer and ask them about the bulletin and update and try that. If that doesnt fix it then I will start investigating the compressor.. Thanks all for the help!!
How do i go to the photobucket account to view your video of the noise? Mine is doing the same thing it sounds like, but of course wont do it at the mechanics. He is saying he needs to hear it to know what it is. Im so frustrated
Originally Posted by momto2babybruces
(Post 149899)
Motor mounts
Have them check your Motor Mounts. The one on the Driver side goes bad.
Originally Posted by ChevyHDNutt
(Post 104097)
Check Motor Mounts
Originally Posted by Willys 53
(Post 104101)
